Published on   April 8, 2026 by Philippe ROSSIGNOL
myCADtools 2026: update your software without administrator rights
myCADtools 2026 SP0 allows users to update the software without administrator rights. Less dependency on IT, more responsiveness for your SOLIDWORKS teams.
myCADtools
In most companies, IT security policies are becoming increasingly strict. Until now, every myCADtools update required IT department involvement. With version 2026 SP0, that barrier is gone: your users can now update myCADtools completely autonomously, without involving IT, while still complying with your company's security policies.
A concrete problem, a direct answer
With admin rights required for every update, the process looked like this: the user reports the need, IT schedules the intervention, the update is installed, eventually. Between the moment a new version became available and the moment it reached users' workstations, days or even weeks could pass.
The result: inconsistent versions across workstations, unpatched bugs, inaccessible features for some users, and an unnecessary burden on the IT department.
With myCADtools 2026 SP0, that cycle ends.
What changes in practice
An update pop-up directly in myCADtools. As soon as a new version is available, an update pop-up appears directly in the myCADtools interface. The user can launch the update immediately no admin rights needed, no IT ticket, no waiting. myCADtools updates automatically to the target version, transparently and without disruption.
 update pop-up in myCADtools
A full version history at hand
All available versions are listed in the interface. Users can switch between versions at any time to roll back if needed or to test a specific release.
Enforce a version across the entire workstation fleet
In multi-user environments, keeping version consistency is often a significant challenge. From the myCADtools shared configuration, an administrator can now enforce a specific version that will be automatically deployed to all workstations using that configuration.
All users move to the same version simultaneously, with no workstation-by-workstation intervention required. Fleet maintenance is simplified, and support is easier to manage.
The benefits for your organization
  • Less dependency on IT for routine updates
  • Faster access to bug fixes and new features
  • Version consistency across the entire workstation fleet
  • Simplified maintenance through centralized deployment
  • Full compliance with company security policies
This evolution is consistent with the broader philosophy of myCADtools: removing unnecessary friction so your teams can focus on their core work. Managing software updates should not require IT resources for every new version. From now on, it no longer does.
