Published on   June 5, 2025 ,  by Communuty Manager myCAD by Visiativ Coralie
Boost SOLIDWORKS with myCADtools
Save time and improve your CAD productivity with myCADtools for SOLIDWORKS. Automation, management, standardization...
Vereinfachen Sie Ihren Alltag als Konstrukteur mit einer Vielzahl von intelligenten Werkzeugen, die in SOLIDWORKS integriert sind.
Do you use SOLIDWORKS 3D CAD software on a daily basis and are looking to save time, standardize your practices or avoid repetitive errors? Between creating drawings, modifying properties, managing your projects and multiple printouts, ancillary tasks sometimes take up more time than the design itself.
That's where myCADtools comes in!
Developed by Visiativ, this suite of over 50 tools enhances and automates your SOLIDWORKS environment. Integrated into the myCADservices Premium subscription, these tools enable you to work more serenely, by accelerating the design process.
In this article, discover how myCADtools can transform the way you work in SOLIDWORKS, with concrete functionalities tailored to your needs.
myCADtools: wat zijn deze CAD-tools?
myCADtools is a suite of complementary tools for SOLIDWORKS, designed to simplify and accelerate the work of design offices. These tools integrate directly into the SOLIDWORKS interface, without disrupting your habits, and enable you to automate tedious tasks, standardize your files and improve the quality of your deliverables.
With over 10,000 users in the industry every year, myCADtools is now recognized as one of the best SOLIDWORKS plugins for improving designer efficiency.
5 narzędzi myCADtools, które pozwolą zaoszczędzić cenny czas
Here is a selection of must-have tools used every day by 3D designers:
🟥BatchConverter
Automatically convert a list of SOLIDWORKS documents (Parts, Assemblies or Drawings) into all formats supported by SOLIDWORKS (DXF, TIFF, PDF, IGES, ...).
🟥SmartProperties
Automatically add custom properties when creating new parts, assemblies or drawings. Gain consistency and avoid oversights.
🟥ProjectManager
Copy, rename, reorganize and clean up a set of SOLIDWORKS files to start a new project on the right footing, without residual links or configuration errors.
🟥SmartBom
Create a BOM from an assembly or folder and use the properties as an extraction filter. Choose the sub-assembly extraction level and concatenate multiple properties in one column.
🟥SheetMetalManufacturing
Automatically export all sheet-metal part layouts from a project to a file.
👉 These tools reduce the time spent on CAD administrative tasks by up to 50%, while guaranteeing greater consistency of deliverables.
Why adopt myCADtools in your design office?
In addition to its features, myCADtools meets strategic challenges for your CAD business:
✅ Improved productivity: every click saved is time saved for innovation.
✅ Standardized practices: files, properties, printouts... everything is aligned.
✅ Reduced errors: limiting manual actions means fewer oversights.
✅ Rapid return on investment: the tool pays for itself in just a few days.
✅ Ease of use: SOLIDWORKS users get to grips with the system quickly.
💬 Use case: "We've gained in throughput time with the SmartBom tool, going from a week to a few hours today."
SEW USOCOME's mechanical design office integrated myCADtools to meet specific challenges: optimizing cost, quality and lead times. Thanks to myCADtools, these issues have been resolved, saving time and reducing errors.
👉 Watch the video testimonial
"With the SmartBom tool we have a much better rendering quality. We can detect design errors quickly and easily correct them" Benjamin VIX
🎯 Your ideal toolbox for SOLIDWORKS
Whether you're designing simple mechanical parts or complex assemblies, myCADtools helps you work better and faster in SOLIDWORKS.
The aim of myCADtools? fewer clicks, fewer errors, greater efficiency.
👉 Would you like to see these tools in action?
📩 Test myCADtools free of charge for 30 days :
